What else do I need?
Con
Just getting started with the install manual. I've got a D1000, ADAHRS200, EMSKIT-L4F, GPS-2020, SV-Xpndr-261, SV-Com-C25H, SV-intercom-2s. Do I need a hub? Do the GPS2020 and Xpndr-261 qualify for ADSB-out? What cables do I need?
RVDan
Frederick, MD
You will need a Skyview network hub. The GPS 2020 and the Xpdr-261 will meet the ADS-B out requirements. If you want ADS-B in you will need the SV-472. I suggest you create a block diagram of the SV net and your components.
owenssonex
Hi,
If your only network items are the 1000, ems, radio, and adahrs. The transponder, 472, and gps are comm ports/pins, not network connections. I have this system with an hdx1100, all my network ports are taken, but I don't need anything more. Hdx to radio and adahrs, ems to radio.
Con
Thank you owen. How do I hook up the EMS through the radio? I thought each had to hook up to the hub.
owenssonex
Hi,
The radio panel head has two network ports. They can be used for inbound or network extension.
Jim
Con
Thanks for that. I can return the hub! And a cable!
