What is wrong here?
DonFromTX
Texas
Fired up my Skyview in the garage this afternoon, trying to make it see the transponder and com radio, something just did not look right here.
Can you spot what is wrong and why it is that way?
[IMG]http://i43.tinypic.com/2vifo0k.jpg[/IMG]
Is your AHRS mounted in the plane and is it label side up?
DonFromTX
Texas
You all guessed it correctly, I had inadvertently mounted my ADAHRS upside down.
[IMG]http://i40.tinypic.com/x5y59v.jpg[/IMG]
thibault
Please tell me about the fittings screwed into your ADAHRS!!!
DonFromTX
Texas
The fittings come in a kit from Avery tools, made up by Safe-Air corp.  You can just buy the fittings if you wish, or the entire AOA/Pitot hookup kit.  I have them on the wings as well, since I have wings that come off easily, they release by just compressing the collar a bit and pulling it out.
[IMG]http://i40.tinypic.com/vzdabs.jpg[/IMG]
legacy
Queen Creek, AZ
The Watts connectors that you get at Home Depot for low pressure water connections work just as well and they are easy to get and inexpensive... ;)
DonFromTX
Texas
I think you are correct. I had recently used some of the Home Depot ones hooking up a reverse osmosis unit, they seem to be of the same high quality.
