Which video camera for Dynon SV HDX ?
JF_Monier
Vendée France West coast
Who could let me know what type of camera can I put on my SV through Dynon video adapter ?
I've tried with some car rear view small cameras, that's work perfectly but I don't know how to remove guidance lines which are unusable, any idea ?
That's a good option to monitor our landing gear operation in case of any problem on system.
Thanks for your help.
PYoder
KOSU
Anyone? Anyone? Would like to install a small camera outside to display on HDX. Someone has surely done it
andresmith76
The camera generates the lines. You have to buy a camera that allows for disabling the lines, usually by clipping a looped wire.
Can you/someone recommend a model or camera vendor they have used for connection to the HDX? I also would like to mount a camera in the underside of my RV-6 to monitor and help with landings.
Man O’War
I ordered this unit, looks like you can disable the lines and reverse image by clipping the correct loop
I will update once I got it sorted.
owenssonex
I use this camera for an inside the cockpit, fuel level status in my Sonex (semi-transparent tank). I also use the Dynon video adapter. 400 hours, the setup as worked great. If you choose this camera, be careful not to cut out the molded Y that appears to have no purpose. In an effort to eliminate wire, I cut this and was unable to get the camera to function, even after examining the wire in the Y molding.
