Widget Labels
The RV8 Pilot
www.rv8-hangar.com
Is there a way to remove/change a widget label? I have been manipulating the user_config file to make better use of the widgets and noticed the RPM has two RPM/RPM labels at the bottom. I want to remove one RPM as well as remove BATT from BATT Volts. Any ideas?
Thanks Michael
The RV8 Pilot
www.rv8-hangar.com
I found that at the end of each pin description the "show units" was set at = 1, I changed it to 0 and that removed the label.
While you can toggle it manually in the sensor file, that's also something that can be toggled in the on-screen user interface too.
