Hello,
I’m getting setup wiring and have come up with some questions.
I’m building an RV7.
VPX Sport
2 – Dynon SV-D1000T
1 – Battery Backup
1 – Adahrs mounted aft of baggage area on shelf
1 – Engine Module
2 – Dynon Comm Radios
1 – Dynon Intercom
1 – Dynon Trasnpoder mounted aft of baggage area
1 – Dynon Adsb mounted aft of baggage area
1 – Dynon pitch servo mounted aft of baggage area
1 – Dynon roll servo mounted right wing
1 – Dynon heated pitot
1 – Dynon GPS Reciever not mounted yet
1 – Autopilot control panel
AeroLeds lighting
I need some advice on routing some wire runs. I foolishly riveted my floor panels in place without installing a conduit run. The center tunnel is going to be a very popular place. I currently have the pitot and angle of attack lines in the tunnel on the pilot side running aft of baggage area and up to adahrs.
My initial plan for the aft baggage area components are as follows. Transponder will have its own run up the tunnel and to the back of the panel. Same for the ADSB I planned on connecting the pitch servo to a serial hub. Run the power lines separate. Connect the adahrs to the serial hub and have just one network cable running forward. Roll servo would be ran to the panel by itself.
What if I do not use the hub? Adahrs will get its own run forward. Pitch servo will run over to wing root connection terminal block and tie in with roll servo. From there it will run forward of the spar to the back of the panel. Better idea? I’m still not convinced of using a wing root connection so I’m open to other ideas.
I understand skyview can be on during engine start. So should I just set the Vpx to have those always on? What should avionics master control? Comms, intercom, transponder, adsb ?
Should the autopilot servos have a dedicated power switch on the panel?
Would it make sense to run an extra wire to the transponder now for possible future connection of a certified gps?
Mike
VPX Sport
2 – Dynon SV-D1000T
1 – Battery Backup
1 – Engine Module
1 – Dynon Intercom
AeroLeds lighting
Mike
