ZAON XRX pinout
Thanks again! Now its ON, but not tested in flight yet.
Heard that ZAON used to have a factory modification that made the unit start automatically when power was applied (so without using any of the buttons on the unit).
ZAON XRX mod for Auto-On/Off:
My ZAON caused a lot of radio static at 120.0. It worked fine otherwise. I had the ZAON TX connected to both my GPS495 and SV RX.
Got Zaon working with right screen on SV, ADS-B 472 on left SV. As i understand its impossible to have both Zaon and 472 on same screen. Is it logical problem or just Dynons idea of how it should to be used?
Would like to connect sound from Zaon to aircraft system. What is better: to connect to Garmin 340 Audio panel or to SV?
I didn't know the ZAON had any sound. If it does, you'll have to connect it to the audio panel. Skyview generates sounds but they also go through the audio panel.
SkyView doesn't have inputs for sound - it outputs it itself. In this case, you'll want to send both the SkyView audio and the Zaon to an external audio panel. Our intercom is actually built with several extra audio inputs to accommodate 3rd party devices like these.
