DATABASE NO LONGER CURRENT... When it is!
Karl Gosling
Hi all, I get the above message when starting my Skyview HDX even though the database is indeed current (a few days old at the time of writing).
The AC was grounded awaiting maintenance for 6 months (May 2025) and now it's good to fly I'm having this issue.
I am on the latest firmware but the problem was there before the update, I was hoping the new FW would solve the issue but no.
Any ideas?
Karl
Does the .dup file from Dynon include PocketFMS charts for you? Because that's what it's saying is out of date, not the Dynon data.
Karl Gosling
The .dup files (PocketFMS files) are a subscription from EasyVFR and the two files you see there are current (AV_DATA and OB_DATA), literally less than a week old.
It's like it's stuck on the May charts even though (as you can see) I've updated to the current ones, this is done every 28 days and I've never had a problem before... but then I've never had a 6 month gap between updates so maybe this is causing some sort of issue?!
Try updating your terrain database. Users outside the US must have a current terrain database installed. Yours is 11 years old, so that might be the problem.
Karl Gosling
The terrain DB is up to date, thats supplied by Dynon and is as current as it gets if you want to take a look - https://dynonavionics.com/basemap-terrain-data.php
The error specifically says my charts are from 15th May 2025, this was close to the last time I flew before it was parked up for maintenance, I think leaving a gap of 6 months between updates as caused some issue?!
Stevec
The terrain databases have not been updated for years but are still current. The check is looking at the obs, nav database and by the wording the charts. Does removing the USB make the problem go away?. I have had issues with my chart provider in the past where they had coded an incorrect currency date in the database.
jaba-who
Cairns, Australia
Same problem ( but maybe different)
I’ve just had to reinstall a repaired older HDX 1100 Screen.
It now also says ”No Hi Res Terrain”
But when I look for it ( if I can find it since I can’t remember how to find the list 🤣😂) it says it is there. It’s an old version ( maybe 2014) but it’s there.
my complicating factor is I’m in Australia and I’m also running Ozrunways in the Dynon so I’m not absolutely sure whether the terrain data bases required are the Dynon version or there’s one embedded in the Ozrunways databases that I’ve down loaded.
To complicate the issue I tried to download the Dynon Hi Res data from this website but it won’t download and says there’s an error and it has been discontinued. the low resolution ones are still downloadable so I’m thinking theres an error rather than truly discontinued service.
jaba-who
Cairns, Australia
Not sure that’s entirely true.
Until yesterday my System worked fine in Australia on the old Hi Res database.
Today after installing a new HDX ( well a repaired old one) and reloading all the updates etc it now gives a “ No Hi Res Terrain” warning but as of yesterday it worked fine On the old one from about 2014.
jaba-who
Cairns, Australia
Follow up
got a very quick response from Oz Runways.
they advise that they Don’t include any terrain data in their updates or files.
so it comes back to Dynon.
Stevec
If it was repaired by Dynon and they wiped the databases you will need to download and install the terrain databases. Usually they come back with update instructions. The one you are missing is the hi res South Pacific database, I think it’s called. Look on the Dynon site and it is there. Yes they have not been updated since 2014 but they are the current ones. Ozrunways only do the nav database file.
The manual says that for non-US databases. But unfortunately it doesn't specify how old is too old. Thought it might be worth a shot.
jaba-who
Cairns, Australia
Yes I agree and that’s the path I thought too.
but as my luck usually works the Dynon page now doesn’t work and the data files needed to do the restore are no longer available. Every world site on the hi res page returns an error basically saying the files have been discontinued.
Funny thing is all the base map and low res files still work.
jaba-who
Cairns, Australia
Yes it’s there but all the files ( for all areas) returning an error.
Birddog
I am in the same boat. All updated - and I get the error - Also in Aus.
Birddog
So here is my error, and I can work it out. Reloaded the data today from OzRunways. Same error.
timtires
I'm try to figure out the best source for database updates. I have a Jeppeson subscdription for Skyview Nav data, a Seattle Avionics subscription and Ifly EFB for wifi (take forever, like watching paint dry). Suggestions?
Birddog
I tried again - still no luck! I have now just given up and live with the silly message that pops up!
Stevec
Bird dog the files you are showing there are the ones on the USB stick. One thought is, is your date and time correct? Is the GPS updating the date and time correctly.
alternatively the validity period of those files is shown on the database information page in the setup menu. I would suspect an old file has been loaded onto the stick in error. I did have one case here in the past where the incorrect dates had been loaded by the chart supplier.
