Angled Panel Mounts
Birddog
Hello All,
I have an RV7 with 2 x Skyview HDX panels and I was wondering if anyone knows of a kit, or a way to angle the screen on the right to be angled toward the pilot. I didn't install them, it was purchased this way, but it would make using the right hand screen WAY more easier than it is now.
Any info you can provide would be awesome!
Regards
J
I don't know of any kit, but it would be fairly simple to build an angled bezel, as long as nothing behind the panel is in the way.
Birddog
Yeah - I am thinking someone with a 3D printer and some 3d printing skills could probably knock one up. I have neither! LOL!
kurtfly
I assume you are looking for something like this panel. The Glasairs have been using these for 25+ Years. They are sold as the vision micro panel. It is made of fiberglass with aluminum inserts. I am sure you could find one for sale on the Glasair owners group or direct from Glasair. You will likely have to adjust the dimension to fit the RV. Also note the SFD (backup display-D-100) area is not wide enough to mount the small HDX-800. So, that area will have to be adjusted.
kurt
Birddog
Hmm.. I don't want to replace the entire dash. Just angle the screen itself. But - yes - angled at the pilot makes a lot more sense.
kurtfly
Something like this? This is for the HDX -1100, will tilt the display 1 inch.
kurtfly
Looks good. How does it attach to the panel?
Thats is a good question. i thought of couple options.
thru screws that go thru the panel but the screws will be angled, requiring an angled shim washer on back side of panel. They could be 3D printed also. But would require acces to both sides of display to install or remove. Could 3D print shim that can accept a nutplate, then glue to backside of panel.
or
you could thread the holes so the display mounts to the angle spacer. Then have additional threaded holes on back side, different location than the dispay uses, to attach angle adapter to panel from back side of panel. If this method is used i an not sure a 3D printed part would be strong enough for the long haul. Have it made from aluminum and anodized. But fit check with a 3D printed model first.
Kurt
You could also angle shim a nutplate, and rivet or screw it to the panel. Then no rear access should be necessary after initial install. Might require countersinking though. Or just use a small flange, if space allows. Hmmm. Food for thought.
kurtfly
I printed out a sample in PLA. It looks pretty good, but I don't have a spare HDX-1100 to check for fit.
Birddog, where are you located? I am willing to send this to you for a fit check.
Kurt
kurtfly
That will not work, I am in Texas. Here is the .STL and .F3D file zipped. You can find someone to print it for you or use a service that is in-country. I would recommend you print it in PLA first then work out any changes. Then have it printed with PA12-CF, or ULTEM, or machined out of aluminum.
I am happy to make any changes you like and re-send the files.
Kurt
  • HDX1100 angled (2).zip
Birddog
Wow! Sweet! Thank you! I will find someone that can knock it up for me. I will come back to you and let you know what I find. Might take me a bit.
Kurt, could you print up a new airplane for me? Maybe a six seat turboprop? Nothing major. And I'm not in Australia. :D
kurtfly
No problem. Here is some #6 nutplate shims set at the panel / screw angle. I counter bored the hole sou you can mount the nutplate on backside with pop rivets or universal head soft alum rivets. you would apply some kinda contact cement to these on first install so they would not fall out when you later remove the display.
  • NUTPLATE #6 5 DEGREE OFFSET.zip
