ADAHRS location
MJH
Thinking about where to position the ADAHRS box on an RV8 project I have just taken over. I see most people seem to build a shelf behind the rear baggage area but as the turtle deck is already fitted on my aircraft is the area beneath the empennage fairing a viable alternative location?
Carl_Froehlich
Yep - shelf. This one is made from scrap 1/4” fiberglass board (fiber core) I got from a Lancair IV builder and some left over J channel from a previous build. Very light but strong.
Carl
tylerpattison
0x44 0x59 0x4e 0x4f 0x4e
I would not recommend putting the ADAHRS in the tail for reasons identified above and because that is quite a distance from the CG. I think the shelf that others have proposed would be my choice and recommendation.
MJH
That is the diagram I saw that prompted my original question. Just wondering if anyone has tried mounting the ADAHRS under the empennage fairing, it would certainly make installation easier and also ease future maintenance access.
Carl_Froehlich
I suspect the ADAHRS module would not play well after it got wet - and that area can get wet. It is easy to mount it as discussed and no less hassle for maintenance. Also keep in mind if you ever want to do IFR you really need two modules.
Carl
birddog486
I didn't want to be a contortionist if the AHARS needed repair so I went this route. This is 2 ADAHRS mounted to the Dynon bracket.
Travis
