ADS-B PARTIAL
dzubot
Edmonton, Alberta, Canada
I have same issues happening in Canada after recently updating my skyview touch. Now ads-b says partial. Was flying yesterday and a guy with ads-b said I was flickering on his display coming on and off. Flight aware track is also showing me all over the place where used to have nice track. As I do survey mapping work grid flying it looks like a maze vs nice grid track. We don’t have ground ads-b here in Canada so normally it says no radar but now just says partial. And going into the ads-b menu says no service. There was a firmware update sitting there for the ads-b and transponder. I have updated it now so will see if it helps. Definitely something got messed up with ads-b after the newest firmware update for the skyview.
Swaflyer737
Just a reminder, the new software removed the "NO RADAR" message and instead displays "PARTIAL". In essences, nothing has changed except the displayed message.
Jimzims
I have been working with the tech support team at Dynon to try and resolve MY issue. If I understand correctly, they are aware of the PARTIAL ADSB message, and are working to correct that in the next update.
I seem to have a separate and unrelated problem with my older 470 not displaying NEXRAD Wx.
The folks at Dynon continue to gather information from me and we’ll hopefully be able to resolve it soon.
Jim
Jimzims
After a “quick update” with the latest version, my nexrad Wx seems to be back.
Still have the Partial ADS-B but hopefully 16.8 will resolve that.
Tech Support was great at Dynon!
Jim
Thanks for coming back and letting us know the results. That's always helpful to future visitors with similar issues.
Swaflyer737
Additional follow-up from me. I did send my unit in as I had exhausted everything I could do as far as testing. I received a warranty unit with NO notes on exactly what was wrong with previous Unit. I installed and flew and issues are resolved as far as i could tell. I was receiving 8 towers in areas where i was receiving none prior to new unit. I spoke with a few other guys at my airport that have both the classic skyview with 470 unit and the HDX unit with 472. They have both told me that they are receiving ABSB OK, but do see the bounce between OK and Partial. My hanger partner said he had a good ADSB the other day, but only after flying south of ATL Class B. Prior to that he had PARTIAL. Once he flew North back under the veil he maintained ADSB OK. He thought that was an improvement from what he had seen previously. Hope this helps somebody.
Birddog
Bit of an old thread and sorry to dig this up, but I am in Australia and purchased an RV7 with 2 x Dynon Skyview HDX panels. I have always had ADS-B Partial in the corner of my screen, but everything appears to be working.
I can see traffic on my screen, and ATC can see me fine (I have asked them to check)
I am not sure if it is because I am in Australia. I don't think we get weather here so maybe that is it?
I have crawled the web, but can't seem to find any answers, so any info someone can provide, or things to check etc, would be great
Cheers
J
That means there is no ground station in your area sending TIS broadcasts, or the ground stations are not sending radar targets. I would assume that's because the ADS-B system is not yet fully fielded in Australia. There were large areas a few years ago that did not have coverage, or had limited coverage, and I imagine that's still the case to some degree. But someone can correct me if I'm wrong.
Correct again Rhino - its a big (almost size of USA) country that has ~ 10% of your population, so a ‘full’ ADSB result is not going to happen any time soon - at least we have some coverage at lower levels near the higher traffic areas. “Looking out” is still a good option IMO.
Birddog
I was actually told by a local Dynon expert that it is because in Australia we don't get weather - AT ALL! So it will never say ADS-B OK. But I can't tell if my ADS-B in is working or not. Especially of there is no traffic to see on screen. :(
The message isn't dependent on weather. Weather is FIS, and that error is a TIS indication.
Birddog
Bob - Are you saying that if I don’t get weather here, it should say ADS-B OK? Or can it still say Partial?
ADS-B capability includes both TIS and FIS, if they're available, but that message is only about TIS. If you get full traffic service (TIS), that message should go away. If you don't, you'll get the message. It isn't dependent on whether or not you get weather (FIS).
Birddog
Hmm right. So my so called Dynon expert needs a new title.
I am not familiar with Dynon gear - this is my first.
Is there a way I can test what is actually not working.
I hove flown this machine across 2 states, that message never changes, but have confirmed that ATC see me perfectly well.
From what I understand here, your system is working just fine. It's the ground stations that aren't giving you all the data the system is designed to use. I would defer to someone with Australian ADS-B experience to tell you how you might 'test' it, such as @jakej, who responded earlier.
GKC Aviation
We down here in the land down under don't get TIS or FIS
PhilzSkyHdx
Classic Skyview with GPS 2020, Xponder 261, and ADS-B 470. All performing well until I updated to 16.6.0 firmware. Since then, I have the ADS-B PARTIAL displayed on Skyview. I don't seem to be receiving Wx anymore. Traffic is fine, METARs fine. Xponder and GPS status looks good in set-up and all is well there.
ADSB Status shows NO SIGNAL and Firmware version is shown as 1.1.0.52.
I've updated the Firmware to 16.7.0 with no change. Antenna is OK visually, connectors seem tight. ADS-B Status Light is blinking red at a rate of about 1 per second, which says the unit is talking to Skyview. Set-up also says there are "0 stations in range, 0 regional nexrad blocks, and so on... all zeros.
I'm out of ideas as to how to restore ADS-B Weather infeed and get back to full ADS-B IN.
Any suggestions appreciated.
I have a similar issue with my Skyview HDX and the latest software update of 17.4.0.2367. I didn't have this error initially after the software update, but the last couple of times I flew (over a month ago) the error was there, so I don't know if this is exactly the same software issue.
Are there any plans or proposals to ever implement those services in Australia? I know you guys get 1090ES from aircraft to aircraft, but is that all?
By the way, saying TIS is being phased out in the US isn't technically true. TIS-A was a standalone service used before ADS-B was fielded. It simply transitioned to TIS-B when it was included as part of the ADS-B broadcast service. So TIS was never actually phased out. It just evolved. I'd go into more detail, but it would be mostly acronym overload, and there's little point.
