ADSB Performance Report
BlueCH750
Low and Slow
Just requested/received report yesterday for my system which includes the 261 transponder, 2020 GPS, and 472 with 15.3.3 software and firmware update.  Passed with flying colors and compliance.  I do have a question though...
The NACv accuracy values (AVG, MIN and MAX) are each reported as "4" and highlighted in yellow .  According to the FAA's ADSB report user's guide, they should not exceed values of "2" and if they do, one should contact the manufacturer to resolve.
Note on NACv: The FAA has not approved, or otherwise evaluated, any ADS[ch8208]B position source  with the horizontal velocity accuracy performance required to transmit a NACv value greater  than 2 (NACv of 2 = Estimated Velocity Uncertainty <3 m/s).  When NACv MIN and/or AVG are  highlighted yellow in the Integrity & Accuracy table of the report (i.e. transmitted NACv  MIN/AVG is 3 or 4) you are advised to contact your installer and/or applicable ADS[ch8208]B avionics  manufacturer for guidance on how to change the NACv value to that approved by the FAA at  certification, or for non[ch8208]certified equipment, a NACv value not to exceed 2 without FAA  evaluation.
Anyone experience this or have any thoughts...Dynon?
Thanks!
See the last post in the thread below. (found using the search feature).
http://dynonavionics.com/cgi-bin/yabb2/YaBB.pl?num=1517678884/0#0
Thanks Ray, got a call back from Dynon tech rep, confirming that is a known issue and will be resolved with the next software update. I though I had seen that thread you linked...just couldn't come up with it through the search function! Cheers!
