1 - If you are seeing higher than actual (your altimeter shows you at 1,000ft but you are actually at 900ft) it means your static source is in an area of "low" pressure so you need to increase it. In this situation you need the tape to be behind the tiny hole. This causes more of the air to press against the tiny hole which increases the pressure felt at the hole. Kind of like the air is running into a "dam".Galin, when you say "Don't tape OVER the entire static port hole, just as close behind, or in front of the holes depending on your error, as possible." Could you explain what side should be taped for what error?
Yes, static port(s) must be on the outside of the fuselage. Just think of what happens if you have the typical "vented inside the cockpit" alternate static source and do an alternate static check while in flight. The altimeter jumps and displays a higher altitude and IAS than when connected to the primary (external) static source. Air pressure inside a flying fuselage is almost always lower than actual (again the Bernoulli effect) which will always show you higher than you actually are, again situation #1. This can be a particularly dangerous situation.And to answer Steveden - I know of an experimental aircraft where the static is inside the aircraft. One pilot reported about a 5 kts change of IAS when he opened the storm window. Clearly one needs the static ports to be outside in my opinion.
Does not surprise me at all. The faster the air flows (airspeed), the greater the Bernoulli effect, the greater the error becomes. In my particular case, at approach speed (85Kts) IAS and CAS were within 1kt of each other while altitude was within 10ft of actual. At normal cruise (143Kts) the Airspeed Indicator had me flying 13Kts faster than actual and the Altimeter indicated I was over 100ft higher than I really was. Since the error got bigger the faster I flew, the main suspect was the Static Port location.Wow! 5 kts, that surprises me for a tube and fabric cub, but I've never done that test. I'll have to give it a try. Thx
If the ADAHRS has a leak then for all practical purposes your static system is "vented inside the cockpit" typically an area of low pressure. This would explain what you are seeing. Let us know what you find.Didn’t get a chance to add the tape, but mothership said to check the Adahrs for a leak, but they think it is a compass issue. I’ll update when I can, may have weather tomorrow. Thanks again!
Thanks Fish, I have adjusted the setting but it still flips. It is a new install, so I have probably done something wrong, just don't know what it is. One note that it will show a tailwind if I am turning, but as soon as the wings are level, back she goes.Pardon me for commenting, but do the speed tests you have done compensate for altimeter (static source ) error? I don’t think they do, but I could be wrong. If so I apologise for muddying the water.
One way - possibly clumsy and maybe dangerous, to test for static error might be to adjust the altimeter setting in flight and observe if there is a setting, close to the reported qnh, that produces a stable wind reading that does not flip, but again I might be wrong.
The TAS on the right column came from checkride.com they are pretty close to Dynon’sUsing the gps to wind and tas spreadsheet from contrails suggests that your TAS airspeed is off by about 12 knots, it should be around 167-168 unless i’m horribly wrong, which is always possible.
That would be above and beyond, but welcomed. I can come your way as well. I have family coming in for the holidays Wednesday but tomorrow, or Sunday Monday would work, or Wed-Thurs next week.According to the numbers you posted I calculated your TAS to be 167Kts (for both runs) not the 181Kts you are displaying which agrees with what SUNFISH posted. This is a +14kt difference in EFIS calculated TAS to GPS only calculated TAS. Take the same measurements at a slow but stable speed (below 100Kts) and see what the numbers are.
I see you fly out of Quincy. I am in St. Augustine so if you want to, take a quick flight over here and we can do some extensive flight testing. Your problem has me curious.
I sent you a private message. BTW, I am assuming you have an VOR/ILS/LOC receiver in your airplane.That would be above and beyond, but welcomed. I can come your way as well. I have family coming in for the holidays Wednesday but tomorrow, or Sunday Monday would work, or Wed-Thurs next week.
