Etienne
*heave*
What's the progress with this very useful feature? I am also suffering with a constant headwind...
There is no way to independently calculate CAS with the information that is available in the EFIS. The only way that Dynon can determine CAS is to calculate IAS (using the pitot and static pressures), and then apply some correction that would have to be based on data provided by the user. E.g. - it could be a table of corrections to apply at different speeds, or a correction that was a function of AOA (if the Dynon AOA/pitot probe was being used). Quite a bit of flight testing would be necessary to determine the corrections for each specific aircraft. Another problem would be that the correction between IAS and CAS would likely change depending on flap position.So, rather than try to "fix" IAS why not just add CAS and use your own method of calculating / adjusting it? Or is that what we are already saying?
GPS altitude and barometric altitude are two different things. It is completely normal, and correct, that they will differ. The difference will increase as we increase the altitude above the source of the altimeter setting.Also - all of my GPS's have generally agreed within a few feet for altitude - why do you say they are not accurate? I even did a "close pass" of a mountain peak of known height, and my GPS appeared to be significantly closer to the correct altitude than my baro.
Unfortunately, although you may have read the answers, you don't appear to have yet understood them. Perhaps I was not clear enough. I'll try again.Thanks for both answers.
When I said my baro was "different," I was referring to rather significant errors (sometimes over 500' variance from GPS at 14,500' - rather disturbing if an aircraft bound the other way had the opposite error!) in my previous aircraft.
I see Kevin, the Static Source Position Error Crusader is at it again. He is bound and determined to stamp out SSPE...
While EFIS and ADC offer the ability to program out SSPE in both altitude and airspeed, the effort and added complexity of programming end-user correction values is, in my opinion, just not worth it. I'd like to see Dynon focus their efforts on other enhancements (like synthetic vision) than giving end-users the opportunity to introduce additional errors into their displays.
99.9999% of end-users just don't have both the flying skills and knowledge necessary to accurately determine what the SSPEs are throughout the flight envelope and then program those values into the EFIS. Even if they did have the skills, they'd also have to spend quite a lot of time do it. End-users are far more likely to screw things up than make things better.
I applaud Kevin's efforts to raise SSPE awareness and get builders to fix the problem mechanically (proper position and shape of the static source) as it addresses the illness, not just the symptoms.
PilotKris
Sorry, I was a bit cranky that despite all my effort to convince you that GPS altitude was not the same thing as barometric altitude, you hadn't appeared to have gotten the message.Hmmm, starting out like that you aren't liable to get many listeners.
Hmm. Now it is my turn to not understand. Which of your statements has not yet been addressed?As it turns out, however, it was neither the clarity of your writing nor my reading of it; it was merely your failure to respond to the actual statement I posited.
I wish it was possible to distill one year to training at test pilot school and 20 years of experience into a few short paragraphs, but that cannot happen. So, please understand that my statements are crafted to attempt to provide clarity on specific aspects of the problem. They should not be relied upon to provide complete knowledge of all aspects of the problem, as there simply isn't enough room to cover all possible bases.Based on factors you have mentioned the Dynon CAN (if all the appropriate sensors are installed) have access to sufficient environmental information (local baro setting, OAT, ground speed, GPS altitude) to compute a good usable approximation of what baro SHOULD read, excepting humidity.
Sorry, but this is not possible to the accuracy that you hope. To do this with sufficient accuracy, you would need quite accurate knowledge of how temperature varied with altitude all the way between the source of your altimeter setting and your altitude. On any given day, the variation of temperature with altitude is often quite different from that assumed by the International Standard Atmosphere. The size of the typical variations are more than enough to make your proposed method quite inaccurate, unless we were close to the ground (perhaps on the order of 1000 ft AGL).I get the variable compressibility of gas. I also get that GPS may not describe a perfect sphere around a supposed theoretical center of the planet. However, the fact that the GPS has an algorithm to determine an "altitude" based on known 3 dimensional coordinates means that, for all practical purposes, GPS gives you an "absolute location" relative to the surface of the earth.
So, stating what I originally posited as an assertion in the form of a question...
Assmptions:
- You know an absolute location in space through GPS
- You have a good "approximate" (closest airfield could be a couple of miles away laterally / vertically) baro setting from ATIS
- You have an OAT not totally out of whack - say within a couple of degrees
- There are otherwise no unusual weather gradients at your exact location that would give you an "unusual pressure gradient" between the surface and your altitude (this is never true for ONE location, but would be statistically true for a system averaging across many days and locations)
- You pick a humidity range from a list of "Visible Moisture; Damp; Normal; Dry; Very Dry" to get you within +/- 20% (again, I think you could ignore this if averaged across many different days and flight conditions)
The Question:
Should you or should you not be able to CALCULATE what an accurate baro altimeter SHOULD read (e.g. +/- 75') given that information?
Fix the problem, not the symptoms.
You've obviously got HUGE pitot static systems errors, most likey SSPE (Static Source Postion Error) if your indicated airspeed is off that much (10%+).
It isn't fair to expect Dynon to fix the problems you've built into your aircraft. Fix the problem and ALL the symptoms go away...
