Autotrim servo controller Beta available
vlittle
I have completed the design of an auto-trim capable 2-axis servo controller, based on the M-PWR-2A from MakerPlane http://store.makerplane.org/m-pwr-2-dual-channel-variable-speed-trim-control/, my business partner.
The controller is now in flight testing, and it is available to other Beta testers who already have an M-PWR-2A installed.  Please contact me via PM if you are interested.  It is not yet available from the MakerPlane store, so I will directly provide you with an upgrade for field modification.
This device works directly with the SkyView system providing 2-axis channel trim speed scheduling, stuck switch fault detection and correction and auto-trim capability.  It does not replace the Dynon advanced autopilot controller which provides 2-axis trim control and (eventually) auto-trim.
It is intended for use in systems that have no panel space for the Dynon controller, do not required the advanced autopilot knob features, or want to spend less money!
Cheers, Vern
vlittle
I have an update on the SkyView compatible auto trim controller. Flight testing is complete and we will be rolling out production devices very soon.
One thing I did was add a tuning interface. This allows external tweaking of performance using a PC serial port, or if my friends at Dynon are willing to support it, by sending configuration commands directly from the SkyView.
I don't anticipate the need for user tuning, but the flexibility is there.
Most of the flight testing has been performed on a Harmon Rocket, which has a very wide speed range and requires a lot of trim intervention when the autopilot is on. The auto-trim controller eliminates any manual trim. If the aircraft is near trim when the autopilot is engaged, it will stay in trim.
Look for a formal product announcement soon from MakerPlane.
vlittle
The controller has been production released since Oshkosh. I have posted the installation guide for the autotrim controller here.  It's hard to find on the MakerPlane site.
Thanks, Vern
  • M-PWR-2AT-installation.pdf
