Nearing first flight and unable to locate the wiring connections to Skyview for the red, black & white wires from the Dynon fuel converters. Can anyone help?
Pins 22 (Violet/Green) and 23 (Violet/Yellow) on the EMS 37 pin harness can be used or any other type C input for the white wire.
Any available ground wire on the same connector or a common ground can be used. You'll need to splice into pin 15 for both converters if you want to power them via the EMS. Else provide a separate power feed that has a 1 amp fuse/breaker.
See page 15-8 in rev Z of the install manual for more detail.
