gteldp71i0
Hi Dynon hope you can help, i have two CHT probes to my Rotax 912s after constant defective readings on the right side probe i started to trace the wiring back to the 35 pin plug and removed the pin from the plug ( pin 4)to disconnect the probe leaving it disconnected the readings still shows on the EMS as an erretic reading ie 300 degrees, whats wrong is the EMS fauty??
