D120 replacement EGT probe reads 60-80 degrees hotter
coorsleftfield
I had an EGT probe failed, and replaced it with a GRT avionics probe, because I figured an EGT probe is an EGT probe, maybe not? I did notice that the length of the probe that inserts into the exhaust is longer on the GRT one vs the Dynon that came out. I'm wonder if this length is something you can adjust before it's clamped down or is it fixed?
jherzog01
At first I thought it might be a configuration issue, but the D120 does not have a sensor selector for EGT probes, stating : There is no need to set a sensor type; any K-type thermocouple will work.
Sorry, no additional insights.
