melkel2000
- Joined
- Mar 6, 2008
- Messages
- 22
I have a D180 in my project that I've had in the panel getting close to a year but it hasn't flown yet since the plane's not completed yet. Everything seemed to work fine with the unit on ships power vs. back up battery until....
Recently, I pulled out the Odyssey battery from the airplane and relied on the back up battery in the unit to test the funtion of each sensor I put on the engine. I'd hook up for instance an EGT sensor, turn on the Dynon, check function, and then turn it off. Evidentally, I eventually ran the back up battery dry.
So, I reinstalled the Odyssey battery to let the stay alive power charge the Dynon. This is what I've seen:
The 1 amp fuse that I have in the stay alive power line would eventually blow, not right away, but over time. I replaced it with another 1 amp fuse and the same thing happened and the back up battery didn't charge.
I replaced the 1 amp fuse with a 3 amp which doesn't blow but the back up battery still won't take a charge.
Once that battery died completly, it has never been able to take a charge. Any ideas?
