Dynon HDX "Direct To" procedure
B1Bjimjim
I am new to flying and the Dynon HDX glass panel. I have tried using the "Direct To" feature on the panel but it doesn't seem to load up. What am I doing wrong? I have search and have not found any instruction. Jim
  • Like
Reactions: RAS
Danerazz
Not really enough information in your post.
This only works when the “navigation source” is the Skyview internal flight plan.
According to the manual, you select a point through the various options (info, nrst, etc.) THEN press “direct” to get it to navigate there.
This only works on the “Skyview” flight plan. If you are using a navigator (GNS, GTN, IFD…) you have to do it on the navigator, you cannot modify the navigation on an external navigator from the Skyview.
  • Like
Reactions: RAS
B1Bjimjim
Thank you for your help! I will be going to the plane ( a 172E that I restored) tomorrow morning and I'll check it out!
  • Like
Reactions: RAS
