Dynon HDX WIFI
pacecapt
Pace, Florida
Why did Dynon design the HDX system so that you need a separate WIFI dongle for every screen instead of just one dongle for the system? I think this might be the reason that the WIFI disconnects frequently from my iPad running Foreflight. FYI, The same iPad when connected to my Stratux never disconnects, so I don’t believe it is the iPad…and no, the most recent SW update did not resolve the issue.
When I was flying in the back seat of the RV8, the WIFI signal strength was very weak and there were a lot of Foreflight disconnect comparing to when I was flying up front. The iPad was mounded 6 inches away from the WIFI dongle and I got an occasional disconnect. However, when viewing the iPad wifi signal, it indicated the wifi was active but Foreflight just gave up. Maybe Foreflight is more sensitive to the WIFI signal strength.
Thanks for the insight. My Dynon WIFI dongles are about 18” from the iPad and my Stratux is 3-4 feet away which also makes me think it is the Dynon and not the iPad or ForeFlight.
My WiFi isn't working properly too, iPad HDX. I've tried everything possible, even with just one Dongle, but without success. I think it's caused by overload when too much data is being processed and there isn't enough computing power for the USB interface. It's similar to when the mouse pointer jerks on a PC.
You need one for each display as any display can be elected the master and that is where the WiFi then gets used from.
You can not manually control the master (unless you do it with power)
Once a master is up, it should not change unless that display becomes offline. You are not switching between the WiFi dongles.
Hi Chris
Thank you for the explanation. If I understand correctly, I can define the master by the power-up sequence of the HDX devices. So if I turn on the device in the back seat later than the one in the front will provide the WiFi. Is that correct?
I started having Wi-Fi issues when I introduced a second iPad that also has email enabled. I set both iPads to "Low Data Mode" in the skyview Wi-Fi and the issue is 99% solved. I believe the issue was my iPad was asking for an email update over the Skyview WiFi.
I will give it a try, thanks.
Hi team. I am also having trouble with Foreflight and HDX. I've got a stratux installed in my plane and it it rock solid, However, I recently bought the official wifi dongle from Dynon, but I'm having stability issues. Mostly the GPS location crapping out randomly in flight. Wifi dongle is plugged directly into the back of the hdx.
I also see 2 devices on foreflight, Skyview and ADS-B.. I had to turn off GPS on the ADSB source to get things working. I've not seen this in any documentation. Is this normal?
Are you saying the Foreflight worked with Stratux before and now it doesn't?
The wifi signal from the Dynon dongle is not very strong. The iPad needs to be located very close to the HDX unit or the Foreflight will disconnect intermittently. I have an RV8. The Foreflight wifi connection from the rear seat is not very reliable. I had to mount the iPad right next to the front panel less than 6 inches away from the HDX unit.
Yes works great with Stratux... however I get some static in my radios from Stratux.. plus I want a ADSB backup. I cannot believe the dongle is that weak.. it's only 2 feet away! Signal indicates strong on the ipad...
I realize you need ADSB back up but does it have to be on? The Dynon ADSB never failed me before. You can always power on the Stratux when the Dynon fails. I don't believe an ADSB failure was reported in the forum.
I've been having a lot of random disconnects from my HDX (v. 17.6) to my ipad 11 (Foreflight app). Ipad is mounted about 2 ft. to the right of my HDX unit. Anyone have a fix? I can believe its a weak signal due to the Wifi dongle being behind a metal panel. Makes me think I should bring the dongle out to the front of my panel on a short cable.
AI says: (just a few things!)
Intermittent Wi-Fi drops between a Dynon SkyView HDX and ForeFlight are
a common frustration in the cockpit. Because the Wi-Fi adapter is hidden
behind a metal instrument panel, several physical and software factors can
interfere with the signal.
To fix the connection drops, work through the following troubleshooting
steps, ordered from the most common software fixes to physical hardware
adjustments.
1. Fix iPad Software Settings (Most Common)
Often, the dropouts aren't caused by weak Wi-Fi, but by iOS trying to protect
your data or switch to a "better" network.
• Turn Off VPNs: Completely disable or delete personal VPN apps (like
NordVPN, ExpressVPN, or Google One VPN) in your iPad settings before
flying. VPNs aggressively monitor network traffic; when they realize the
Dynon Wi-Fi doesn't have internet access, they will silently drop the
connection to look for cellular data.
• Disable "Private Wi-Fi Address": (check in Cockpit)
Go to your iPad Settings > Wi-Fi, tap the "i" icon next to your SkyView
network, and
Turn OFF Private Wi-Fi Address and Limit IP Address Tracking.
This prevents the iPad from constantly cycling its network identity, which
drops the panel connection.
• Turn Off "Ask to Join Networks": In the main iPad Wi-Fi settings page,
change Ask to Join Networks to Off. Otherwise, if your iPad catches a stray
Wi-Fi signal from a hangar or airport terminal while you are taxiing or flying
low, it may try to disconnect from the Dynon unit. (done)
2. Configure Dynon's Apple Connectivity Mode
Because the Dynon Wi-Fi does not provide internet, iOS will sometimes flag
it as a "No Internet Connection" network and drop it in favor of your iPad's
cellular (LTE/5G) data.
1. Go to your SkyView HDX unit.
2. Navigate to Setup Menu > Wi-Fi Setup.
3. Look for a setting named "Show Wi-Fi Symbol" or "Wi-Fi Icon on Apple
devices" and toggle it OFF.
• Why this works: This changes how the Dynon broadcasts its network
parameters. It tricks the iPad into treating the Wi-Fi purely as a local data
feed, preventing iOS from dropping the connection to search for cell
towers.
3. Relocate the Wi-Fi Dongle (Physical RF Interference)
If your dongle is plugged directly into the back of the HDX screen, it is
trapped between a solid aluminum chassis and a metal instrument panel.
This creates a severe shield against radio frequencies (RF).
• Use a USB Extension Cable: Plug a standard, high-quality USB
male-to-female extension cable into the back of the HDX, and route the
wireless dongle out from behind the panel.
• Mount in Line-of-Sight: Secure the dongle somewhere under the plastic
glare shield, or tape it to a composite panel section where it has a clear,
unobstructed line of sight to where you mount your iPad in the cabin.
AI: To narrow this down: Does the connection drop at specific times
(like when you pass near airports with cell towers), or does the SkyView
network name completely disappear from your iPad's Wi-Fi list when it
happens? (and so forth...)
FYI, after upgrading from Classic to HDX, I had to use extensions to get the Wi-Fi to have a clear line of sight to the iPad. This meant having them located below the panel edge. Then they worked fine. Otherwise they kept dropping. I also had to upgrade the Wi-Fi dongles to the latest versions. If I had to guess, I would say that the metal fuselage causes lots of reflections that confuse the signal. Someday I will have to take a Wi-Fi tester to the airplanes and experiment a bit.
Every so often I'll start up and get a Wifi Offline message. No pattern to it that I can discern.
Normally it seems like the connection is fine and I can get traffic etc. on iFly, but for some reason I'm unable to push flight plans over. It worked early on in Phase I but I haven't been able to get it to work again.
For those of you who are using the Stratux, I urge you to be very cautious!
Two years ago, a number of us were flying to the same destination when a C182 in the group called on the radio and said they just lost all their GPS systems; Garmin 430W, iPhones, iPads, etc.
He cycled the power on each unit, one at a time, and nothing fixed it. I formed up on his left wing, about three feet away and my HDX and other GPS systems were not impacted.
Eventually he turned off his Stratux, and like magic, all his GPS's came back online. It turns out that this is a known issue.
I am not saying don't use the Stratux, but be aware that it can interfere with your GPS reception when it fails. Since you are obviously Dynon customers, the obvious solution is to install the Dynon ADS-B solution and remove your Stratux. In my friend's case, he upgraded his Garmin transponder to one that includes ADS-B in and out.
Fly safe!
Can you please provide a reference to this known issue? Thanks, and Blue Skies!
You will have to Google it. It was two or three years ago when his failed and I remember Googling it and a found a few references to the failure.
You don't have to remove yours, just be aware of the issue and should your GPS drop out, it COULD be a result of your Stratux.
adjustments.
network, and
towers.
So I checked all the settings that AI suggested on the iPad using ForeFlight and in my Skyview HDX unit. I flew the airplane for two hours today and it was solid with no dropouts and I did not relocate the Wi-Fi dongle.
