On my last flight, i was reminded how painful it is to get METAR info from the map. Would it be possible to add the METAR info to an airport's bubble info? Or something similar?
For instance, i want to get a wide area of cloud base information. I go to MAP and the color coding is certainly helpful. However, I have 5 airports in an area all blue. I want to see what the reported clouds are.
Right now, you have to select the airport, INFO, click right about 4 times to the WX tab. Then read through an entire page of wx detail. Then BACK once or twice to the MAP. Repeat. Painful!
Or you to cursor to near the airport, hit NRST, click right only 1 time to the WX tab. Then scroll thru the list of airports, but you lose the context of the MAP. Then BACK once or twice to the MAP again. Slightly better but you would hope there is an easier way than this too!
It sure would be nice to just go to the MAP page, touch the airport, info bubble shows METAR under the airspace. Touch another airport, info bubble shows METAR. All while never leaving the MAP screen.
What do you guys think?
