I have a different ammeter shunt than the one supplied by Dynon, so I need to edit my Sensor Config File to change the c_X1 constant. I have the downloaded "duc" software file on my desktop computer. Does the software update need to be installed on the HDX system and then the Sensor Config File "exported" to the USB drive before I can edit it? And then, can I import into the HDX that edited Sensor Config File from the USB drive?
Second question... If I change my Sensor Config File and at a later date, install a software update, will my Sensor Config File get overwritten by the update? I think I read somewhere in the documentation that it does not get written over? But I also read that it is "updated" with new sensor definitions? Does that mean that the update process reads the Sensor Config File and remembers my definitions and then "merges" the updates with my existing custom sensor definitions?
Thanks!
Mike
Thanks!
Mike
