d3mac123
- Joined
- Oct 6, 2020
- Messages
- 93
I just tried the emergency glide feature today. There are my findings:
- Glide ring stills a circular ring - not sure if it is considering weather/terrain in this case (the ring in FF and Garmin Pilot is not circular at all);
- First try (no airports near by) only said "EMERGENCY GLIDE NO VALID AIRPORT". In the second try (with an airport in the glide range), the message was "EMERGENCY GLIDE ACTIVE";
- Autopilot is automatically set to ON (in the case it was OFF), as expected, trying to capture glide speed;
- GPS draws the magenta line to the center of the airport, as expected;
- Although the radio was set to the chosen airport, none of the frequencies were automatically set to that (I was expecting this TBH);
- Differently than Garmin's Safe Glide, no options to set transponder to 7700 nor radio to 121.5 was offered;
- It wasn't clear how to "cancel" the feature (for example, in the case you could restart the engine). I ended up disconnecting the autopilot.
I will try to edit a video for tomorrow.
