EMS- lost signal on #1 EGT
pgtuck
Two year old fully functional Dynon complete panel system is RV6A. Last week #1 EGT stopped working. #1 EGT read out has a red X on it. Absolutely no data. The attached picture is from the EMS setup menu.
Replaced #1 EGT with new sensor. No change!
Anyone have Thoughts on possible resolution? Thanks in advance!
Carl_Froehlich
Replace the spade connectors. This is the problem more often than a probe going bad. You can get them at Aircraft Spruce or Stein:
If memory serves, you want the 1/4” wide spade.
The wires are thin so I typically add a #22 wire along side the probe or EMS wire to fill in the connector.
Carl
pgtuck
Carl
Thanks for your reply. Already replaced connectors plus pulled wires from D-sub connector and, replace new D-sub pins. Open to any and all ideas!
Carpe diem
I had the same problem 2 years ago: I changed 2 sensors to no avail ...
I then solved only by changing all the engine wiring, 912 and Sport, as a badly tightened clamp had caused damage to the cable due to unwanted vibrations. The wiring was poorly installed by the manufacturer ...
