Flap position alert for IAS
jnmeade
Eastern Iowa
My experimental SkyView HDX already displays flap position. Can it generate an IAS-dependent aural or visual warning using three separate limits: above 62 KIAS at 30° or more, above 80 KIAS at 15°, and above 100 KIAS at 0°, with reflex permitted above 100 KIAS? Can this be configured natively, including defined behavior between flap positions, or does it require an external device?
Plane is Flgiht Design CTSW. Position indicator takes readings from the potentiometer on the linear actuator. Flap actuator is set manually by moving a switch, so it is infinitely variable and does not have stops, although the POH gives limits per several given flap positions. I modified the flap actuator so this is not like a standard FD.
Back
