ForeFlight not talking to SkyView
N82JN
Recently my iPad/ForeFlight has stopped talking to my SkyView Classic rendering unable to upload/download flight plans.
I have the WiFi module installed on the SkyView and the iPad does recognize and receive the signal - so I know that SkyView is broadcasting the wifi signal.
But when I try to export a flight plan from ForeFlight to Skyview, Skyview does not recognize of find the Foreflight.
Advice and recommendations are appreciated.
K.N. RV9a
lancair360
I’ve seen this once or twice where it’s getting GPS and ADS-B from Dynon but the flight plan transfers aren’t available. Restarting the iPad always fixed it for me. Don’t know why it’s happening but I suspect it’s on the iPad / ForeFlight side and not the Dynon side.
N82JN
I tried to close and restart ForeFLight - no luck. I shut down and rebooted the iPad also with not results.
djones
Administrator
Check the Local Network switch per the image below. This one is for FlyQ, but Foreflight has this also.
lancair360
Well I'm stumped. Did you try simply disconnected from the Dynon Network and reocnnecting? Otherwise I'm out of ideas. Sorry.
kurtfly
Are you using VPN? It will not do flight plans if you use VPN.
kurt
Dynon101
I love flying!<br />
I had the same problem... this fixed it
