waiter
I know this has been covered, but I'll ask again:
Is there anywhere that I can edit the Fuel Level Lookup table.
What took hours of reconfiguring my fuel system, then emptying / refilling tanks, could be done in about two minutes of editing the lookup table, Looking at the sensor calibration sheet for one of my level sensors; 2.63 volts is empty (2630 = Dynon value)) , 1.65 volts is full (1643 = Dynon Value) , The tank is liniear and I have the calibration sheet from the factory.
I spent about three hours to calibrate the level to the Dynon, I'm not happy with the results and will not do this again. Its to much of a pain in the butt, and I don't like the hazard of defueling / re-fueling my tanks in order to re-perform a calibration of the sensors that was already done.
PLEASE - Provide a utility that I can edit the lookup tables. If not, at least give me a hint of where to look in the raw EMS backup file.
I looked in the raw backup but didn't see anything obvious, maybe my next step is to convert the AD values to Hex, then see if/where they show up in the Raw backup file to see if there is a coorelation there.
Waiter
Waiter
