GNS480 Interface
N714b
RV-8A
Rochester, NY
Has anyone successfully connected a 480 to Skyview using the wiring diagram in the SV installation manual? If so, what settings did you use on the 480 and SV?
skysailor
Bob, I also have a 480. I looked to see your email to send you a copy of settings I got from the Yahoo 480 Users Group but it was not listed. The Skyview Installation Manual has a diagram showing the connection of the 480 to the ARINC 429 adapter. If that does not answer your questions, shoot me an email and I will send along the note I mentioned previously.
Here's the settings that work with the HS34, which you should be able to adapt for SkyView. Should be a good starting point, anwway: http://wiki.dynonavionics.com/Garmin_480_Wiring. You want to look at the second table.
