GRT CS-01 Installation (Number of Loops?)
badia358
Mebane, NC
I am installing the GRT CS-01 in my Skyview system and I have a couple of questions:
1) How many times do I need to loop the wire (8 AWG) going from the alternator to the load buss?
2) I will be connecting the BLUE wire of the GRT CS-01 to the EMS D37 pin 18 (+5V). Is that correct?
3) Any other items that I need to consider for installation?
Thank you...
GalinHdz
KSGJ/TJBQ
You are correct in that the CS-01 gets connected to the EMS D37 pin 18 (+5V). I just don't remember the wire colors.
FWIW, I use the CS-02 to monitor the load since it handles up to 50A and my airplane consumes much less than that. YMMV
GalinHdz
KSGJ/TJBQ
One last thing is to make sure you select the correct file (CS01 / CS02) when you configure your system. Depending on your installation, you may have to calibrate the configuration with an offset to have an accurate amps display.
