mikemalone
- Joined
- May 12, 2017
- Messages
- 36
I have installed 2 Skyview HDX displays. Aircraft not yet flying. I had successfully installed the displays and other Dynon products, including EMS 220, ADAHRS 200/201, Autopilot Servos/Panel, XPNDR 261, COM-X83 and Knob Panel. After some time since all the electrical installation work, I switched the power on and now have a problem with display number 2 (no problem with display number 1). The display starts, goes through its test sequence and ends up with the red cross with the messages 'EMS FAIL' at its centre and 'MAP UNAVAILABLE WHILE DATABASES LOADING.' Shortly afterwards, the display turns off. The fans still operate at this point. I was also quick enough to press the CAUTION button and recorded the following messages just before the screen powered down: B/U BATTERY UNAVAILABLE, SINGLE ADAHRS, COMM RADIO PANL OFFLINE, EMS FAIL, ADAHRS FAIL, AP PANEL OFFLINE, KNOB PANEL OFFLINE, SOFTWARE MISMATCH and B/U BATTERY TEST NEEDED.
I recently updated the databases on display 1.
The second display does not appear in the list of Dynon equipment under DISPLAY HARDWARE EQUIPMENT.
