Hi Folks,
RV-8 with D-180 +HS34 +AP74 with 2 servos connected and powered. No other avionics fitted yet. Still building the avionics.
Have updated the D-180 and AP-74 without problem to V5.5.0 but unable to update HS-34.
After start D-180 shows red network configuration error message which I clear (I always get that).
The knobs on the HS-34 make no difference to the displays on the D-180.
Config check shows all 5 devices and no errors.
Procedure and symptoms during update are is as follows:
1. Connect laptop to HS-34 via RS232 connector and power down D-180 via left switch.
2.The HS-34 GPS light is on but the Nav light is on but very dim (maybe light from the GPS light?) These lights are always like this so this is no change.
3. Start Product Support Programme and select Detect Firmware version.
4. The PC displays "connecting" then " attempting connection on Comm 5"
5. After a while I get an error message "Error Connecting to HS34 - Can't find instrument on any serial port.
I have checked the continuity of DASB A and B from the HS-34 to all the other connectors on the bus and they are all good.
Any ideas please?
John RV-8 builder in UK
Any ideas please?
