Fellow pilots,
This is going to be the thread for HS34 wiring questions. Please understand that the product is not shipping yet and we cannot support all configurations. We'll do our best to answer what we can here.
DO NOT call our tech support line about the HS34 wiring yet. They are not trained on how it connects and don't have any additional info. This thread is supported by the engineer designing the HS34, so you should get some pretty solid answers
So here we go:
The HS34 has two D25 connectors on it. The upper one is male on the HS34 and is power, DSAB, etc. The lower one is female on the HS34 and is the ARINC and analog resolver interface.
Upper D25, male on HS34, female connector.
Pin 1: Serial 1 RX (PC updates & second serial port)
Pin 2: Serial 2 RX (SL30, GPS, etc)
Pin 3: DSAB A
Pin 4: + In (10-30V, 700ma MAX at 12V)
Pin 5: GP Output 1 (Same as EMS, not currently supported)
Pin 6: GP Output 2 (Same as EMS, not currently supported)
Pin 7: GP 1 in (same as EMS GP in)
Pin 8: GP 2 in (same as EMS GP in)
Pin 9:+5V out
Pin 10: GP 6 in (+15V GP in, not currently supported)
Pin 11: GP 5 in (+15V GP in, not currently supported)
Pin 12: GP 4 in (same as EMS GP in)
Pin 13: GP 3 in (same as EMS GP in)
Pin 14: Serial 1 TX
Pin 15: Serial 2 TX
Pin 16: DSAB B
Pin 17: Ground
Pin 18: Digital input 4 (not currently supported)
Pin 19: Digital input 3 (not currently supported)
Pin 20: Digital input 2 (not currently supported)
Pin 21: Digital input 1 (not currently supported)
Pin 22: Marker Outer Input
Pin 23: Marker Middle Input
Pin 24: Marker Inner Input
Pin 25: Voice audio output (8V P-P, you'll probably need an external attenuator)
Lower D25, female on HS34, male connector.
Pin 1: CDI + when deflected right
Pin 2: VOR + when TO flag shown
Pin 3: LOC +
Pin 4: GS + when up UP
Pin 5: GS + when FLAG shown
Pin 6: DME Analog IN (0-8V, 40mv/NM)
Pin 7: Resolver E
Pin 8: Resolver D
Pin 9: Resolver F
Pin 10: ARINC 429 RX 2 B
Pin 11: ARINC 429 RX 1 B
Pin 12: ARINC 429 TX B
Pin 13: ARINC 429 TX B
Pin 14: CDI + when Left
Pin 15: VOR + when From flag shown
Pin 16: LOC -
Pin 17: GS + when Down
Pin 18: GS + when Flag hidden
Pin 19: Resolver A
Pin 20: Resolver C
Pin 21: Resolver E
Pin 22: ARINC 429 RX 2 A
Pin 23: ARINC 429 RX 1 A
Pin 24: ARINC 429 TX A
Pin 25: ARINC 429 TX A
