Re: Jabiru 6 Cylinder Motor -  Mags and RPM
Our recommended RPM pickup in a Jabiru is an alternator wire. This would be totally unaffected by your mag check.
Sounds like the RPM was installed using the mag P-lead output rather than the alternator. In this case, you must hook up two RPM wires, one to each mag, so that the RPM doesn't drop out when checking your mags.
Which wires to use and how to attach them is covered in your install manual.
