KLN 90B WITH SKYVIEW
Bruno
Hello Support and everyone interested
I just finished installing a Bendix/King KLN-90B in my RV-4 which is connected to my Skyview.
I thought I will post the ARINC 429 set up here for anyone interested in going this route ( Cheaper than a 430 )
You do not need to hook up the KLN-90B to the Skyview via serial port.
The set up requires an Arinc 429 module and is very strait forward to install.
Once install, go to the Set Up menu in the Skyview to set up the ARINC 429 module.
Here's the set up
INPUT SPEED : LOW ( HIGH doesn't work )
INPUT 1 : GPS X this will be what the Dynon will show the imput is from ( I used GPS 2 )
INPUT 2 : NONE
OUTPUT SPEED : HIGH
NAV SOURCE : GPS 2
The Skyview will display the purple line to your waypoint and the distance in the Nav Source box same as any other GPS.
Will update the Database of the KLN-90B this week and check to see if SKYVIEW displays the route ( Flt Plan )...will report if it does.
Hoping it helps anyone going this way.I had someone helping me out and it was very useful. Thanks Brian )
Bruno
SkyView doesn't currently import / crossfill flight plans from other devices. So if you're getting HSI guidance, you're working!
Bruno
Hello Support
        My pleasure on the report.
I will be updating the database of my KLN-90B soon and will report  back.
Are there any plans about making the Skyview able to import/crossfill flight plans from other devices??
In the meantime I can always load every waypoints of the approach in the Skyview and crosscheck with the KLN-90B.It is a bit of work but doable..
Bruno
It's on the features roadmap, but couldn't say for sure whether the KLN-90B will work (we'd likely target the 430/GTN for compatibility).
ricardo_godoy
Bruno...
you can let me know the pin out/pin in for conection kln90b x SV arinc 429 module??
tks.
Bruno
Hello Godoy
I'm in Europe right now and don't have the info in my Ipad but I have them on my computer at home and will try to remember to send them to you when I go back home.
Cheers
Bruno
Bruno
Godoy
Check your PM, reference the PIN OUT for a KLN-90B to an Arinc 429
Cheers
Bruno
Bruno
Hi godoy
Standing by to send you the info I've got if still required..
Bruno
ricardo_godoy
I appreciate all the information you can send.
in Brazil, we have a few users skyview.
we have one of the largest fleets of single-engine aircraft in the world, but the cost of up-grades of avionics is very high.
some make use of options as the skyview, which is financially very attractive. :)
rlallen1
does this installation with the 90b also require an annuciator display?
TRCsmith
Suisun City, CA
Yes. You can manufacture it yourself or purchase one.
Read the install manual "free on line" and it will list the requirements once installed to be IFR legal
