No GPS Position Source
Zazoos
Hey Gang,
Turned on the DYNON HDX for the first time today. Everything seems good except for the "No GPS Position Source."
I opened up the two dsub connectors to verify wiring is correct and the pins are seated and no broken wires. Everything looked great.
Here is what Port 5 is showing with everything looking like it is correctly wired. RX Counter is increasing fairly fast.
I swapped the grey/violet and grey/orange wires and plugged it back in. Here is what Port 5 is showing. Group errors is increase slowly.
Thank you,
Trent
GalinHdz
KSGJ/TJBQ
Does the GPS antenna have a clear unobstructed view of the sky? Not inside a hangar or anything with a roof over it.
Zazoos
2020 model and I did roll it outside of the hangar.
Thank you,
Trent
Ricardo Godoy
I had the same problem with a classic and 250 gps. After updating the software, it returned to work.
DBRV10
Brisbane, Qld. Australia
You say you have a SV-GPS-2020 but your settings show you have selected the SV-GPS-250.
Try selecting the correct one.
AND make sure you have the wiring correct, dont go swapping anything.
Zazoos
Hi Ricardo,
Yes, the problem was it was set to GPS 250. Change to 2020 and it worked great.
