Loud aircraft, all menu settings maxed out and volume knob on SV-Com is turned all the way up. Volume is almost adequate but sure would be nice to be able to get a bit more out of it. 2 SV-700 displays with audio outputs tied together as per the installation manual, all sounds work and apparent but again, would be nice if louder. Airplane is using a PS Engineering Audio Panel, this response from PS:
"The audio panel (all of our audio panels behave the same because they are all based upon TSO’d product) provide only unitary gain. We do not provide amplification of the radios. It is interesting however to learn that the ICS volume is fine but not the two radios. I suspect it may be a limitation of the output of the two radios.
Our output amplifiers can put out 8.5 volts peak to peak into a 150 ohm load. So this is what I would look at with your radios. They may not have enough output voltage to drive your headphones loud enough.
FYI, the headphone amplifier you are using is the same exact headphone in all of our PMA7000 and PMA8000 series audio panel, so with over 50,000 in the field, we have gotten surprising good feedback from the owners of warbirds, aerobatic pilots, and all sorts of certified aircraft.
I wish I had an answer for you but I do not unfortunately.
Are there any tricks to increase the gain in the Skyview products, most importantly the SV-COMM? I like my COMM loud and readable. No issues with transmitting Mic Gain seems fine.
DP
DP
