flyingforfun2004
- Joined
- Nov 23, 2008
- Messages
- 38
I am not getting a oil pressure reading it stays on 0 bar. Dont panic i have tested with a manual guage and i do have pressure.
I am using the new type oil pressure sensor (Honeywell 3 wire) I have a couple of questions do i have to take the 12 v from the dynon or is it ok to take it from my 12 volt bus ? I ask as this is how i wired it and i didnt want to rip it out if i dont need too.
2. Should i connect the ground ? I can see the sensor wire links using the 200 ohm resistor to ground but should i connec the black on the sensor to ground or not. I assume it will be grounded to the engine anyway.
Regards
Kev
Regards
Kev
