This can be due to rising or falling air in the atmosphere from localized heating. You can pretty much eliminate this as a factor if you take a test flight early in the morning before the sun has a chance to heat the ground and generate thermals in the atmosphere, or by flying very high (10,000'-12,000' or better, if you can get there).
The autopilot will attempt to maintain a level altitude at all times, and if the air outside is rising, then the airplane has to go nose-down to maintain that same altitude, which will also increase your airspeed. If the air outside is descending, you'll go more nose-up to maintain altitude, and airspeed will fall. Do you see any variation in airspeed during these changes in attitude?
