maartenversteeg
- Joined
- Oct 26, 2011
- Messages
- 230
Still running my Skyview setup on the bench in the (wooden) garage, but installed the new 15.3 version software and updated the 472 firmware. I now saw my first plane reporting it's overhead position. Prior to the installation the Skyview system would come on when I switched the battery power on and when I switched the battery off the Skyview would count down from 30 and shut down (or when the stay on button was pressed keep running on the Skyview battery.
Now the Skyview will no longer 'see' that the external battery power is switched on and I need to press button 1 to get the Skyview to power on. Once powered all seems correct and the Skyview reports normal voltages on the bus (14.5 Volt) and the internal battery reports charging. Similar happens when the (external) battery is switched off, Skyview doesn't see this and only by pressing button 1 the power will shut down. This means that I don't get the dialog 'counting down 30 sec' or the option to start the internal battery test.
Has anything changed with the new software release, is there any configuration setting that controls this behavior?
