I got my Skyview in March 2011 with firmware 2.6. Until my new airplane arrives, I did benchtesting the unit and setup all required parameters for EMS. Meanwhile I made some updates, so it had firmware 3.1 (not 3.1.1) installed.
I did several flights with the Skyview (SV-1000).
These components were installed initially:
- SV-ADHRS
- SV-GPS
- SV-EMS
- SV-XPDR
- Serial port connection of Garmin GPS, Zaon etc.
- NO SV-BAT at this moment, due to space requirements!!!
On 17.July2011 I took care about the battery-installation, also testing better places for the ADHRS. During that process, I had to switch off the SV1000 several times, NOW with SV-BAT connected.
After may be 5 times, the unit shows following failure:
- Power to SV1000 switched on
- 20 seconds black screen but fans running
- than white screen for 5 sec
- than powering down
- than the same procedure again
- after switching off the power, nothing happens, because it runs from the back-up battery
Sending in the unit, got back a repair-unit:
- same behaviour with firmware 3.0.
- without SV-BAT connected no issues!!!
- as soon as SV-BAT is connected, system f.…-up at next powering up.
BUT
- This time the screen shows white with several coloured stripes and remains on after cycling up and down 3 times.
Is that behavior solved when updating to firmware 3.1.1???
Background Information:
Could it be, that there is a problem with power-switching to SV-BAT of the SV-1000:
In my airplane all the avionics is connected to an avionics-bus and switched on by an Avionics-Master Switch.
The Avionics-Master solenoid is powered by the Master-Switch – so this Master has to be ON to activate the Avionics-Switch.
Additionally the Master powers an electric capacitor (ELCO) which prevents power-peacs destroying the avionics, also power lost to the avionics by high power demand (my assumption). Consequently, when power is lost due to failure of the battery or when the Master is switched off (while the Avionics-Master is ON), the power decreases slowly.
When the Master was switched off (with Avionics-Master ON), I recognized, that it takes several seconds, before the SV1000 shows the counter to shut-down and the SV-BAT takes over - thats because the SV1000 still sucks power out of the capacitor.
After powering up again, the SV didn`t power up and shows that behaviour mentioned before.
In no way the unit should fail even when power is decreasing slowly!!!
The new firmware 3.1.1 was available on 21. July 2011, so no chance for me to load it up before.
Chris
- SV-ADHRS
- SV-GPS
- SV-EMS
- SV-XPDR
BUT
Chris
