an.tarducci
- Joined
- Apr 22, 2010
- Messages
- 28
I have a Dynon EFIS D100 and EMS D120 connected with "DSAB".
I mount the "Dynon AOA pitot Boom Mount" on leading edge of the wing.
I did the calibration as instruction, but "AOABAR" displays a single red line!!
I repeat the calibration, but the result is the same.
I noticed that the plane carrying a high angle of attack, you see all the red lines and yellow (not green), and subsequently decreasing the angle of attack is again displayed a single red line.
I Have done something wrong?
I checked the hose connections and all seem correct.
Furthermore, even on the ground (zero speed) only one red bar is displayed
The only imperfection mounting pitot tube is that it has a slight angle of attack compare to level flight (the tip of the pitot is slightly higher)
What can i do to solve the problem??
p.s. i have experience in assembling a "AOA Pitot". last year i installed an "AOA Pitot" in my old aircraft with Efis D10A, and everything worked fine.
Another problems:
On EFIS D100, in Data Logging Menu
I am seeing and error 4 message.
What does this mean and how do I clear it?
i have a Firmware 5.2 (on EFIS and EMS and I did not see where the error appeared after the firmware upgrades).
Many Thanks
Andrea Tarducci
Another problems:
Many Thanks
Andrea Tarducci
