anyone with their panel wired up who is using skyview please help out with a simple test of the rf noise from the skyview...
first power the minimum panel for tuning a radio with the skyview on...
tune a marginal station (atis inside of a hangar should be a good test) listen to the quality of the transmission, clarity, static, etc.
now turn the skywiew off... how does this effect the radio signal?
is your unit a 10" or 7"?
for me, the skyview swamps marginal signals with a layer of noise and noticeably degrades good signals, very strong signals are not significantly impacted. i get similar results even if the skyview is removed from the plane and powered with a benchtop source not connected to the aircraft in any way.
an 'advanced flight systems' unit in another rv appears to behave similarly, but the d10 in the same plane was rf silent.
dynon has replaced the screen (no change to projected rf noise) and has directly observed the rf noise at my hangar.
rf noise from my skyview even degrades fm radio reception from a shop dewalt radio from across the room.
i remain hopeful that the observed rf noise is only an issue when ground testing and that it is not a factor when flying... i really like my skyview and am not interested in going another direction but it is quite frustrating that the units appear to consistently generate dirty rf.
yesterday i stopped by dynon to pick up a set of the capacitve filters that they have come up with to address the rf noise from the leads on the skyview system. after installing them there is no descernable difference in reception from the aircraft radio with skyview on or off.
it is important to install all three of the filters, one to each of the db9 connectors and the db37... in my testing i initially installed a single filter to the db37 line without much impact to the noise... with all three in place the skyview unit appears to be rf silent.
robert at dynon noted that the usb tail coming from the db37 connector would not work with the filters (i had already removed mine) and that they would be making them available on request to anyone as soon as they have stock.
here is a shot of the filters installed; you have to reverse the connector studs on the filters.
