kurtfly
- Joined
- Jun 21, 2014
- Messages
- 257
Dynon,
I am wondering what the input impedance is on the "Low Voltage" tach inputs on the SV-EMS. I have dual P-Mags with SV connected to the Tach signals which outputs 12 V signal. When I connect to the SV the Tach signal drops to ~5V. The P-Mag has an output pull up of 4.8K ohm to 12V. This calculates the SV input impedance to ~3.5K ohm. Is this correct? Seems very low?
The SV tach indications works OK; however, I want to add an Electronic Ignition Commander to my aircraft which needs the tach signals also, but must be >8V. Will moving my SV tach to the high voltage inputs increase the input impedance? If so to what?
Kurt
Kurt
