Notarpilot
- Joined
- Jul 16, 2020
- Messages
- 10
Can anyone tell me why ADS-B targets would intermittently disappear and reappear throughout a flight using the HDX?
I believe you need to be on release16.5.2 or higher to be able to load the latest SV-ADSB-472 firmware.My SV's ADSB-472 is Version 2.4.20 and I get occasional dropped targets, ghosting, etc. Can I separately update my ADSB to the newer Version 2.4.58 without having to go through the whole 16.6 update? I always dread the updating process due to my fear that my existing parameters and settings (for my RV-12 / 912ULS) will be lost or incorrectly reset.
Schorsch - I'm curious how your learned about this new ADS-B update and the fact it doesn't install automatically?Just noticed yesterday that there's an update for the SV-ADSB-472 ADSB-IN that didn't install automatically on upgrade to 16.6... somewhere in SETUP > ADSB-IN.
Only got 30 minutes to fly with the update, and leaving the TIS-B disabled for now to see if the update helps.
To avoid messing up my existing Van's RV-12 ULS parameters in my SV should I just update to 16.6.0 using Dynon's Method 1? In other words, NOT try to update any of my existing Van's sSV ettings??DHeal, I have a 12iS, and after wiping out all of my settings by using the Van’s update file, I’ve since always just used the Dynon file. I’m currently running 16.5.2 and just today updated the ADS-B firmware. Be advised that if you have two HDXs, you need to power off the second HDX before updating the firmware. Had to get Dynon support to help me fix that issue. And by the way, they responded several times within the hour of my email request to help me out. Outstanding customer service! And according to Van’s, their update file isn’t supposed to wipe out our settings, but admitted there have been a few updates where that happened, so, fool me once shame on you, fool me twice…. You know the rest of the saying.
That’s what I do. You do need to review the Van’s readme file for any changes you may need to implement manually. For example, one of the settings changes they made for the iS was to eliminate the yellow range from the fuel pressure widget. Since I didn’t use their update file, I had to manually change the fuel pressure widget. And I’ll just repeat that Van’s claims their file isn’t supposed to change our settings, so proceed as you see fit. You can always save your settings and reinstall them if the Van’s file causes a problem. Dynon automatically creates a backup of your existing settings before loading the new file, but it’s not placed in the root directory, so you would need a pc to move it to the root to be able to reload it.To avoid messing up my existing Van's RV-12 ULS parameters in my SV should I just update to 16.6.0 using Dynon's Method 1? In other words, NOT try to update any of my existing Van's sSV ettings??
From a recent email exchanged from Dynon Support I learned that ADS-B, Transponder and GPS updates all have to be handled manually. The process for each is detailed in the installation manual. https://dynonavionics.com/includes/guides/skyview/SkyView_System_Installation_Guide-Rev_AO.pdfSchorsch - I'm curious how your learned about this new ADS-B update and the fact it doesn't install automatically?
After installation, did you notice any improvement?
I appreciate that reminder. My question was based on how we are supposed to know there is an update available for any of those devices? The Dynon Release Notes page doesn't really give users a firm indication an update is even available:From a recent email exchanged from Dynon Support I learned that ADS-B, Transponder and GPS updates all have to be handled manually. The process for each is detailed in the installation manual. https://dynonavionics.com/includes/guides/skyview/SkyView_System_Installation_Guide-Rev_AO.pdf
The only way to know if an update is available is to manually check the ADS-B / Transponder / GPS setup pages after every firmware update to see if they need to be updated.I appreciate that reminder. My question was based on how we are supposed to know there is an update available for any of those devices? The Dynon Release Notes page doesn't really give users a firm indication an update is even available:
Dynon Avionics | Software Updates and Downloads
Download and get updates to the latest SkyView Software for either HDX, Classic, Touch or SE.dynonavionics.com
According to an FAA document from September 2022 TIS-b is not being phased out….FYI TIS is being phased out at the ATC level, and may only have spotty coverage at this point in any case.
