Squeal when push to talk
austinglasair
I am getting a squealing noise when pushing to talk on my Dynon radio. I have a full hdx Dynon suite. I have tried different push to talk switches, new microphone jacks, different grounds. Normal intercommunications between pilot and copilot are loud and clear. I'm out of ideas. :eek:
I love aviation!
Try turning things off one at a time to see if it is associated with something else in the plane. These problems are almost always due to poor grounding or a ground loop.
austinglasair
That was attempted and failed to clean up the transmissions. I've tried from pilot and CP sides. I believe I've isolated it all the way to the COM radio unit. Looking for bad grounds now.
One way or another it is typically the grounding that causes squealing.
Pm me if you wish & I’ll talk you through some troubleshooting- results can be posted on here later.
Cheers,
Jake Jansen
Glasair IIS FT (2500 hrs)
djones
Administrator
Try connecting a decent gauge ground wire between the com radio transceiver case (use one of the mounting bolts with the paint cleaned off) and run it to the intercom case. We have fixed quite a few of these with this ground wire. Give it a try.
W
William_Ince
Please let us know if Dynon’s solution worked for you.
Thank you, in advance. :cool:
