Surefly setup on Skyview EMS P-lead connection
Has anyone installed a Surefly EI in their aircraft? There appears to be a RPM issue with other EMS systems , I am attempting to determine if there is any issues with using the standard wire currently used for the Magneto with the resistor attached, before i start taking things apart to find out...
forum.flydynon.com
Anybody else installed Surefly yet? I did a drop-in replacement. Unfortunately, when checking the mag drop on Surefly, the RPM reading goes to ZERO. That is unfortunate.
I am connected as the Dynon Install manual recommends under the section P-lead pickoff (Lycoming and Continental) pg 7-47. Uses two 30k ohm resistors.
https://www.surefly.aero/faq According to their FAQ, the p-lead sense line might be an issue.
Does the SIM output a tachometer signal?
The SIM outputs a 60Vdc spike with a 10Vdc offset on the p-lead (2 pulses per rev for 4 cylinder models & 1.5 pulses per rev for 6 cylinder models).
Hoping for any suggestions!
Jae
