Ludovit_Palaj
- Joined
- Jul 9, 2017
- Messages
- 3
Hello, we have SportCruiser with 2x SkyView D1000 installed professionaly by CzechSportAircraft. The plane is based in europe, Slovakia. Both displays has it's own SV BAT.
First I'd like to say, that we realy like the SV system, which works nice and fine.
But last month, one from our displays doesn't start. After switching master and EFIS's switch nothing happened. The screen is absolute black, with no sign of any activity. I tried to switch on the display by pressing and holding button No 1 But nothing happened. Day before it works correctly. Yesterday I wanted to remove the display from plane to send it to USA, but display started to work. I flew 3hrs and everything was OK. After that I checked the backup battery (from setup menu), which has 10.34V and display can work from main source and also from backup batery.
I want to ask you for any advice/help what to check before we will send display to dynon support center, or if it makes sense. To chcek or download any error log, to find problem description maybe.
I checked the cables and everything looks fine, no loosen or overheated or disconnected cables...
I was thinking about SV BAT are discharged, but the display doesn't work it doesn't started on primary power suply. The second display works fine and the voltage was > 12.0V
SV-BAt is now discharged and I can't perform battery test. What's the correct way to charge the backup batery? Switch the display on from primary source (plane batery) and connect the primary source to charger? Is there any other simplier way to charge the SV-BAT?
Thanks for any advice.
