We no longer recommend that the SV-INTERCOM-2S be used with two COM radios. We're revising the SV-INTERCOM-2S manual to reflect this changed recommendation.
If you wish to use two COM radios, we recommend that you install an audio panel from PS Engineering.
[list bull-redball][*]When two COM radios are used with the SV-INTERCOM-2S, there is no way to mute (audio from) the second COM radio when one COM radio is transmitting.
[*]The SV-COM-C25 does not support the "interlock" signal that is a feature of most other COM radios.
[*]The requirement to use a Single Pole Double Throw (SPDT) to switch the PTT signal so that only one COM radio transmits at a time is a poor user experience.
[/list]The second COM radio input is still present in the SV-INTERCOM-2S, so if you decide to connect two COM radios to an SV-INTERCOM-2S you can do so; but our recommendation is not to do so.
Hi Dynonsupport,
can you please tell a bit more about the issue why only one COM should be used with SV-INTERCOM?
In my panel modernization project I would like to keep the old 25KHz spaced Collins COM for emergency and add one SV-COM-X83 (+SV-D1000T,...). I have an old simple audio amplifier with fading performance I would like to swap. Wiring for two COMs and external switches to toggle mike input etc. can be left. Therefore SV-INTERCOM would be perfect.
Thx, Stefan
