I have more and different information, but still no solution.
On my set-up the squelch on the intercom is minimum at the 10 O'clock position.  Without the engine running if squelch is at minimum the music circuit is always muted. At 12 o'clock the music circuit is interrupted but plays some times. At 3 O'clock the music circuit operates normally.  Max squelch is at about 6.
With the engine running the music circuit works up to right at 2000RPMS , regardless of where the squelch is, and will not operate correctly above 2000.
Now, I have (I think) gained another piece of data.  Turning the com unit off and leaving the intercom unit on and the music circuit works up through 3500 rpms. I assume it will work up to 5000.
If I push the squelch button on the com unit (which turns the squelch off) it is fairly obvious (to me at least) that I am hearing a lot of engine interference.
So I went into the com menu and turned the squelch from 50% TO 80% - that had no effect.  I also varied the side tone, but that did nothing either (did not expect it to).
When I go into the menu for Mic Gain it has the notice that 50% should work and gives instruction on varying the gain while continually saying "test" until "good" shows up on the menu - well, no setting would produce "good" - it always shows "low".  Just reporting - not thinking that is involved.
SO, it seems the com unit is interfering with the intercom vis-a-vis the music circuit.  I will have to say that the amount of "noise" from the com unit when its squelch is disabled is very substantial, though it does not interfere with com traffic when the squelch is on.
Does this give anyone any better ideas?
The installation manual for the com unit suggest putting a VSWR meter between the unit and the antenna to test the ratio.  That brought to mind that I used the antenna that was already installed which was for a Garmin SL40.  Does this raise any alarms?  IS this a test I need to perform?  If so is there an inexpensive way to do this?
THanks
Bob
