Trim calibration
Spcialeffects
I have just finished wiring up the EMS harness and have an issue. I have a Ray Allen trim motor fitted. The white/blue wire is grounded to pin 13, the white/orange to pin 18 and the white/green to pin 23. When i go to calibrate the trim motor i go all the way up and then down but it tells me that there was no change in the value and so when i operate the trim the indicator on the widge doesn't move.
What could be the problem?
Many thanks Frank
Spcialeffects
Hey Ray. I'm not sure what your asking? The wire from pin 23 is violate/green, which I have connected to the white/green from the Ray Allen loom. When you say configured correctly what exactly do you mean? What is the process?
Thanks Frank
You need to tell the SV system which pin (of several available) you are using for trim indication. This would be under EMS configuration in the SV setup.
Spcialeffects
That would make sense and I'm pretty sure I haven't. Will check and reply tomorrow.
Thanks very much Ray[ch128077]
Spcialeffects
Hey Ray. Thanks very much for your push in the right direction. I found that screen where you tell the system which pin has been used for what purpose and all is good.
